Injectors
Acdc88
I have a set of 42# injectors that I will be installing when I make the N/A to Turbo jump. I also have a new set of N/A injectors. now my stock injectors are beginning to act up. Can I install the 42# injectors, and adjust fuel pressure to compensate for the increased pressure, or should I install the stock replacements I have and just wait for the turbo to go 42#?
i will also be installing a front plog and 1.84 yt roller rockers later in the month, so could I benefit from slightly increased injector flow over stock at that point? (Hv3 and u bend delete installed)
Your adjusting flow rate in lb/hr not adjusting your fuel pressure. Input the correct injector data and it will drive just like stock
The injector flow rate is the only adjustment needed. With my limited tuning education, as far as I know there is no way to increase the fuel pressure
