Injector removal
RobGTP
on an L67 motor do you have to remove the intake manifold to take the injectors out, or can u just pull the fuel rail and pop the injectors out? The car is misfiring and stuff and ive tried everything else. Its throwing a code for injector on cylinder 1 so im going to replace all the injectors.
Release pressure from the fuel lines.
Unbolt the fuel rail.
Lift and wiggle slowly on the rail pulling up on the injectors as necessary OR unclip all 6 injectors and pull the rail up seperate from the injectors.
Don't forget new O rings and make sure you clip the new injectors into the rail on the right notch so you don't have any leaks.
