Injector oulsewidth drops after 5700 rpm
w3tbanana
So I recently did a topswap on my 2005 Buick Allure, and it runs real good. But for aome reaaon my injector pulse width just drops after 5700 rpm in WOT. I dont feel like its a sensor issue, and if I try to command more fuel it still just drops. This is causing leaning out. I checked the fuel pressure while going into WOT. It stays at 58-60 psi. I do have 60lb injectors in right now. I dont know if there is a bad ground or something else going on. Any ideas on where to start my diagnostics?
Sent from my SM-G920W8 using Tapatalk
Post the tune file as well.
Remove the 1 bar map channel and replace it with the 2 bar map channel so you can read boost in the scanner. I'm assuming you are running a 2 bar map. Something seems off if your wideband is correct. You are commanding 12's but your wideband it always in the 13's at WOT.
Ya, so I dont know. Ill do that and check my fuel pressure again while doing it. See how ot works out
http://www.grandprixforums.net/thre...-project-planning/page2?highlight=swap+sensor
Read the last post about why your 2 BAR map may not have worked for you.
These computers are so limited on what you can change and watch because they have so little data. But I could see an issue with the baro/map going screwy and causing it to lean out as it doesn't know exactly what is going on.
You talking about the baro sensor?? I will look into getting a second sensor setup for it. I dont know of its because the GTP has two map sensors or what. I didnt think my car had a baro, but I can read it.
So I added some fuel up top. And it did not help any. Injector pulse width still goes from 9 to 7 during WOT. Any other ideas?
Ya ive got a single bar map which is what the pcm ran with originally. I was thinkimg of making the fuel injectors smaller seeing if that would help.
