Indentify connector help
I couldn't tell you exactly what the connector is called with a wire diagram but that's one of the main harness connectors for the top of the engine. Likely has the cam/crank wires, injectors wires, ICM wires.
any mods going on in there? nice light car, should fly.
and thats still the main harness side of the crank and cam sensor harness plug you need. im shocked it still runs wells like that. a lot of pcm info flows through that harness.
that harness ties the icm and crank and cam sensor. and some thing to do with fuel together. time to hit a junk yard and lop one off any 3800 powered car you find.
Fuel injector signal to ecm really weird it run but havent actually driven it just idle and revving it up dont want to get stranded somewhwere test theory
