in take temps
on ideal conditions a good intake temp would be near outside temps.
if its 80* out and your runing 103* then there is still improvements that could be made with your intake.
even with a good intake you should expect to see intake temperatures around 100*. when youre actually moving they should be pretty near ambient.
your air intake temps are going to be read before it hits the supercharger, so an intercooler would not change those readings, BUT at the same time and intercooler cools are GREATLY. it would greatly benifit the eaton.
and dont think just because your intake has a box it wont heat soak when stoped, my wizair does it all the time.
Normal intake temps for Hot air intake or stock air box are anywhere from 20* above ambient to 140*. That Is what I got when testing it out.
