Felix
Alright guys, been having a weird problem with my 02 GTP. Basically when I try to start it after its been sitting overnight or for a couple hours I can turn the key two clicks forward, hear the fuel pump run, and then as soon as I try to start the ignition, everything cuts off, and I mean everything. I try to restart it and it wont, I wiggled the positive and negative terminals and that sometimes restarts it and I get power back, but then the second time I started it the motor ran for about a second then died. I waited about 2 minutes and tried again and it ran. I have no problem with the car while it is running.
The positive and negative terminals look fine and have no acid build up or too much rust, the cables are also nice and tight and properly secured. My battery is about 6 months old, granted it was a battery for a Malibu. Apart from just losing power entirely, could a bad throttle position sensor help with a hard time starting up?
Thanks for your time.
