Ideas for amp rack or such with 2 amps and 1 12 inch sub
Mount it on the rail where the seat back's hook into.
Magically out of your way.
Put subs in the glove box.
You never know when you might break down and be stranded for hours, subs are good cold.
Real easy...look at my install. Add a false floor that sits on top of all that and you're done!. You can hide it in your spare tire well even.
He just said hidden...never mentioned anything for space requirements ;) He'd be losing about 4 to 5 inches with a false floor. If he was able to put it inside the tire well he might lose an inch...
I was ponderin mounting my 8CH ads amp under the deck where the stock monsoon amp goes. I think it'll fit
and its hidden then ;) sorta.
i was just going to make a false floor that wont cover the spare, on one half the subwoofer will be bolted to it and on the other a simple 2 level rack. i think that should work, im hoping anyways...
