IC pump went out need Info
Shaq7607
I have the IC stage 2 set up from ZZP with a gen 5. I just noticed the pump went out, not sure how long it has been out. I just overnighted a new pump from ZZP. So by saturday if it ships tomorrow. What kind of damage can it cause if it drives when the pump is out? Also, is ok to drive in short distance without the pump? Thanks in advance for an info you can pass to me. I have a 2002 GTP
youll be fine short distance wise. just dont be going WOT or anything as obviously your IC will not be functioning.
Alright thanks guys. Yea ill def be keeping a light foot especially since I can hit close to 15 psi with my set up.
It's misleading that your sig doesn't mention you no longer have an M90 on the car.
Misleading yes....but I own 2 GP's
99 2dr E85 car in my sig (For clarification this is the car that hit's 16.5psi)
98 4dr Turbo car (new DD)....only turned this one up to 14psi so far.
