I wrote another thread on mentioning about replacing the gaskets as preventative maintenance. The car is an 02, 197k.
Today I was looking around the upper intake manifold around the back and noticed coolant or something dark pooling along the bottom of the upper intake right on top of the lower intake manifold, and this pooling was going all the way the entire length of the bottom of the upper intake manifold by the fuel injectors. I looked in front along the other side by the fuel injectors and there's what appears to be coolant piddling near one or two injectors right above the upper intake manifold. I pulled the oil dipstick, and the oil looked and smelled normal. I looked at the bottom of the oil cap and it wasn't milky, but I noticed some 'condensation' that surely wasn't oil. I rubbed my finger underneath the oil cap and put the tip of my tongue on this 'liquid' that was on my finger tip from the oil cap and it tasted SWEET like coolant!!!!!! I opened the radiator cap, and it appears there's green coolant mixed with dex red carp.
I've read that the intake gaskets are known to leak. But in my research I've also read about head gasket issues. I've also read about the upper manifold melting near the egr port and needing replaced. I've also seen a youtube video where the lower intake needed to be replaced because the red coolant corroding the lower intake surface. I've also read dormans lower intake manifolds are garbage. I'm getting a little paranoid reading all this.
I've owned the car 3 weeks. I haven't been losing coolant or that I've noticed. It runs amazing and it DOESNT overheat or run hot. I'm getting no white smoke from the exhaust.
So what should I do? replace the upper and lower gaskets and go from there? could my head gasket be shot?
Are those dorman gasket kits that include a new upper intake manifold any good? they have the dorman upper manifold kits for $59.99 on eBay right here that includes the egr pipe sizes; http://www.ebay.com/itm/Engine-Inta...iter_Display:3.8L&hash=item28085df13d&vxp=mtr
auto zone sells the fel pro lower intake manifold gasket with just the gaskets and sealant for $39.99 here. should I get the lower intake gaskets from fel pro and buy that dorman kit for the upper intake online? that seems like it would have everything I need to get the job done minus having to get the coolant elbows seperate
