I need a Stock 2002 GTP.bin, HPTuners
Quicklynx
As the title says. I had several tunes from my 98 on my laptop. I had some problems with the car and had put the stock tune back on. A nasty virus hit my computer and all the work I had done is now gone so I need to start over. I'd like to start with a Stock 2002 .bin file this time. I use HPTuners software.
Thanks guys, I will really appreciate it.
Drop the 2005 GTP timing table into your stock bin and work from there. The newer timing tables are a much better starting point.
Hey Josh, when I did a system recovery on my comp I lost your excel table modifier you gave me, would you mind sending me it if it's not too much to ask? Also do you have the 2005 GTP timing table?
Thanks
Thanks
Sure, get me your email address and I can email you the stock 2000 bin with the 2005 timing tables in it, the two excel sheets I use, and the Table Modifier Thingy.
Josh this is exactly where I am at. Is it possible you still have a 2002 stock Bin and the 2005 GTP timing table.
Any sugestions beyond the error below would be greatly appreaciated: Hoping the new 2002 GTP Bin above will allow me to forgo the error below and save a Basic Tune Bin for DHP PT. Thanks
Error #: 73, Severity: 1
This is an unsupported File Type!
Please contact DHP for further assistance! (0/-23206)
VIN # : 1G2WR5215YF327185
Block 0A ID # : 0
Base Model # :
End Model # : 0
Seed : 326D
Interface Ver #: 2.6
hey RMCardle.... I don't think Josh is on here much anymore as he no longer has his GTP. I may still have the files he sent to me as they would be stored in my gmail account. I'll check for you.
The latest OSID for the VIN you posted (1G2WR5215YF327185) is 12201788. I was going to attach the file, but apparently I am not allowed (got an 'Exceeds your quota by 89.5 KB' message).
Here is a link -> http://theblattners.com/gtp/12201788.zip
If you are a DHP customer, you can download a 2005 bin from the site and copy/paste in to your 2002 bin. If you own a PT but don;t have access to the forum, let me know.
:th_thumb-up:Thanks for the great info. I be trying this out today. I'll check back here later today to post results. Thanks again.
