I just put engine in need help
Need more info with complete sentences.
What car, what motor??
Double check all plug in, grounds, fuses etc etc..
If the starter just clicks, then you have a grounding issue.
As long as you hooked up the ground and starter wires properly, then your battery is questionable. Check connections at the grounds, starter and then battery terminals
Thanks I haven't had much time to get out and work on it I'm almost positive it's a ground issue
