Iron Indian
Ok guys,
I have a slight issue I cannot seem to figure it out. I'm really in need of some help.
Recently I just got done ridding my car of Garlock gaskets, so pretty much removed everything above the LIM. The IC, S/C etc. I RTV Both sides of both S/C gaskets and reinstalled everything. I had my TB redone by Brain (did a fantastic job BTW, I definatly recommend his work). When I got the TB back I cleaned it out with carb cleaner and what not. I noticed the TB blade didn't look adjusted right and I could see a good amount of light around it. So I adjusted the set screw so it could close better. I turned it until it barely cought and backed if off a 1/4 turn so there would be no interferance.
Why did I mess with this? Well about 4 years ago somebody had a free mod where you would take your TPS sensor, drill out the holes so it could be adjusted. After adjusting it to a certain value you'd adjust your TB blade. Well I tried it and it didn't work good for me, infact it made my tranny slip! So i reversed it, or so I think anyway, its been so long. Anyway, i never had a problem again.
Today I was driving my car, and it was running fine! Ran smooth, oil pressure good, vac at 19-20 in vac, everything looked, ran, and sounded good! With that said, I was flipping though my Scanmaster checking various values and I found one odd problem. My IAC were going anywhere from 15 to 0. WTF?
I went home, all evening i've been messing with adjusting the TB plate etc. A couple of times I got the IAC at 130 at idle and off at 255, then adjusting more it would go back to 0 and 120 off. Basically what it does, I start the car, it starts at 57 and rapidly drops to 0. Car runs good, sounds good. Once it threw a code, which was PO1404. Which is an EGR code, Makes no sense to me, I don't even have an EGR! Haven't had one in years. I checked all the vacuum connections. I used a can of carb cleaner on the whole engine bay and no funny idling at all. Other than the scanner saying the IAC at 0, the car runs and drives fine! The vac at idle is at 19-20 in vac, so thats good. I don't think the IAC is bad either, I took the one off her car and tried it in mine, same issue. Put it back in her car, and her car runs fine and the IAC are where they always were.
I'm baffled, help?
I'm baffled, help?
