just acuired a 1999 grand prix gt with 158k on it.needs right front brake caliper etc..brake caliper was ok i replaced the hub napa $ 90.00 now on to leaking radiator? any brand to stay away from?/QUOTE]
fans work,but they will not turn on when engine temp goes to 220... and i tested the relay volts on the base of fan relay,,no 12 volts on pin 30,,one trouble diagnoses site says it is a open on the orn-1250 feed to pin 30..any help...
check the temp sensor under the t stat housing in the lower intake manifold. and its wires, they bake in the heat from the crossover. it controls the fans.
not really, the pcm runs the car much better then the old days, tells you when theres a problem, then leads you to the cause.
i do miss the old days of timing lights and re jetting carbs, but the new is here aint it lol
the thing is if one sensor goes bad, the rest suffer due to no communication with each other. mpg drop, performance is also lost most of the time. depending on the code that pops up.
tuning is way easier these days, if you know how to do it. a few clicks of a mouse and you can play with your timing, fuel and so on.
