HVAC vents not changing
Jakegday
hey guys. went to use my A/C last night when i noticed the MAX A/c wasnt working. It would blow cold air, but it would not go into recirculate mode. Then after that i noticed air just came out of the front vents only, no matter what position the switch was in (floor, vent, defrost) The switch still makes the a/c compressor kick on when its switched to max a/c or defrost, but the vent position doesnt change. I checked all vacuum hoses under the hood and everything looks fine, (although i couldnt find one specifically that goes right into the HVAC unit) I paid special attention to the areas around the spark plugs and wires i recently changed, but couldnt find anything suspicious.
Any suggestions on where to start?
can anyone at least tell me where under my hood i would find the vacuum line that goes to the HVAC unit??
NEVERMIND. Just found the vacuum line i was asking about. apparently it runs near the battery, where it joins a wiring harness that then goes through the bulkhead (firewall). because of this, its in the perfect spot for corrosion from the battery to fall/drip on to the line and cause it to corrode/melt.
