What are your future plans for this car? Togs are a tad extreme for an n/a car.You were spot on . . . I didn't follow the correct torque sequence and torqued the plenum, preventing the gasket from sealing at the coolant ports. Got everything sorted out now. Foueled the plugs from the coolant leak though. i can get it to start and run but will be replacing the plugs and injector o rings this weekend. Luckily I walk to work.
I appreciate your advice! On a tangent, I will be installing TOG headers and zzp 200 cell catted downpipe sometime in the next month. Is there any benefit in increasing the injector capability since I'm opening the airflow through the motor? (Cai>hv3>headers>downpipe>stock cat back.) I think stock injectors are ~22#. Any insight you can offer is appreciated.
