So I have a 2003 Grand Prix Limited Edition 96k miles. The thing is sometimes it will start just fine, sometimes it wont start just cranks... If you spray starter fluid into the intake it will start, will idle forever if you let it sit and run. If you drive it, it will shut down once it's 1 line over quarter on temp gauge. The fun part, I have changed: Alternator, Crank position sensor, Cam position sensor, Intake air temp sensor, Throttle position sensor, IAC valve, Ignition control module, Fuel pressure regulator, fuel filter, fuel pump, fuel pump relay. I have had it to the garage for over 6 hours, diagnostics seem to check all within specs on snap on ultra computer. No check engine light no stored DTC's, I am for a loss on this and if I don't get it fixed by this weekend I'm going to lose my job, have been trying to fix this for 2 weeks now and have spent well over $600 any help appreciated.... also I teste the injectors for power, they have power when you turn the key forward and cranking.
Thanks, Joe
Thanks, Joe
