hp tuner serial/usb input software
SgtMarshal
Active member
so I sent hp tuners an email and asked: I am wondering if you are going to support a serial/usb input from an auxiliary device like a wideband?
I should have phrased my question a little different and asked if their software would be updated to support serial/usb inputs from auxiliaries like a wideband because the response I got was:
unlikely with the current generation of hardware.
I'm not sure if this is the correct spot for this thread. kind of a rant, but kind of a tuning question.
what do you guys think?
Why do keep complaining about this? Either get the pro and wire it up or wore your wide band into your system and scan it that way. I'm not trying to be a dick but I do not get the confusion or frustration with it.
You don't want two separate inputs going into the pc to be logged as one. You want everything feeding in from one source. That way there can be no lag or different timing of the two items being logged.
Hence the pro version with inputs on the side of the box.
