How to unplug coolant light? Help please
The coolant level sensor is on the passenger side of the radiator in front of the positive battery connection. Reach in and unplug it. Be sure to check your coolant level often, though.
Sent from my SkyRocket
So all have to do is pull out to unplug. It won't leak, correct?
you can unplug it, yes. no it wont leak.
you can also take the sensor out of the rad, clean it. cause its likely gunked up with dex sludge. then put it back it, good chance it will work right again.
Check it often? LOL
Scott.. you'd think these guys never had a car w/o a level sensor on the rad. Sheeeeeeeeeeeet kids, when you smell coolant or see a puddle, that's when you check that out.
Check it often? LOL
LOL, Bill! Just trying to cover all bases. Most people nowadays rely on a light to tell them when to do things...
