How to turn off daytime running light on 2008 GP
More than likley pull the DRL fuse. It is also likley a 10 amp red fuse. That's how you do it on 97-03 anyway.
you can't, at least thats the conclusion I've come to after posting many a thread and had no sucess with my 07, only option was modifying the pcm
well then even the sugestion I got from one member about modifying the pcm is junk, turning off the daytime running lights while driving just can't be done as far as I know
Has any one tried to pull the DRL fuse to see if it works??
wait never mind. i can turn the head lights off but not the orange lights at the bottom. once you put it in drive they come on. if you run with the foglights on tho it dont look bad
