BillBoost37
To pull the trans apart to do this.. I like to do this.
Drain trans fluid
Support motor from above.
Unhook endlinks
Pop both balljoints
Remove 2 18mm bolts holding ps rack to subframe
Unclip ps cooler line from subframe
Remove any plastic clips holding wiring to subframe
Undo two 15mm nuts on engine mount to subframe and 2 15mm nuts holding trans mount to subframe
Lower subframe (4 x 18mm bolts)
Pull driverside axle
Remove as many trans side cover bolts as possible
Now lower the motor/trans (tilting a little to the driverside if possible)
Remove any remaining side cover bolts and lower assembly until you can wiggle the cover out.
Gently unhook the wiring harness for the trans
Unhook the valve slide that is connected to the shift cable (in this pic on the lower right, see the metal rod? That's what you need to unhook at the end we can't see that is under a soleniod.)
Remove the pump from ontop of the VB (black screws only, leave that silver one in to hold the pump together)
Pump off
Remove bolts 230, 231, 377, 805, 433, 434, 435, 436, 374, 379, 380, 384
This will get the VB/channel plate as one unit.
Replace hub shaft, clutches (if applicable) and channel plate gaskets.
When doing the gaskets. You'll notice there's one pin at the end of a long gasket. This is where the spare M6 bolts come in. Looking at the vb/channel plate combo, determine where you can put a bolt and still take it out once the assmebly is back in palce.
Here's the 4th clutches, the part they engage in the middle is the hub shaft
Removing the clutch plates, pull the shaft and note a plastic shim/bearing on the shaft. The nubs of that sit in the drive gear where this came out of.
You will likely need to vigorously wiggle and turn the new shaft to engage it in place. Then put the clutches back in place (note orientation of the notches etc as the channel plate has to clear them) and it'll all go well.
One thing you can check while you are there is the drive chains. You pull them with a finger toward the bottom of the case and the measurement to resuse changes IIRC needs to be 1/8" or more.
More pics here Login to a private Photobucket.com album
Password if needed is "Boosted"
Easy
Drain trans fluid
Unhook endlinks
Pop both balljoints
Pump off
Easy
