how to splice l67 injectors into a 01 gt
nascartech
well im top swapping my 01 and the conectors are diffrent then my 97 l67 injectors just want to know what color goes to what thanks im pretty sure i got it figured out just want someone to confirm
All you have to do is get any Haynes repair manual and check to see which color is -, andwhich is +, usually with injectors it does not matter, they will work either way.
Basically, you should be able to get away with just connecting the wire, I suggest first connect with a good crimp tool, and the solder the crimp connection, then heat shrink, them cover with the corregated tubing, that how I have done all my injectors on my projects.
Dean
ya i just looked at the wireing and one wire has a black strip so that got to be ground and the other is just a solid color as for connecting them i was gunna twist them solider them thet heat shrink them
Just make sure to do a good job soldering the wires, and use heat-shrink tubing. It's your friend.
