how to replace the snout on a gen 3 m90
hollas13
I'm askng ths question because I have 3.4 mps already pressed on a snout and want to just replace it all as one.
It's rather simple...use a syringe and drain the supercharger oil and then remove the 9 bolts that hold the snout and case together.
I fugured that much didn't know to expect if there's a gasket on the snout can't find anything like that at the local auto parts store not sure what to expect inside
Like said above its pretty simple to do. Make sure you have rags under the snout to catch any excess oil that doesn't come out with the syringe.
If it's an MPS. buying a 3.8 would be cheaper generally unless you already have the new snout
Wear gloves do not get the old SC lol on your hands or you will hate yourself for the week and do it outside if its possible. The smells bad you don't want that inside.
