How to replace Supercharger Bearings
BillBoost37
Removal is either done with a blind pilot bearing tool or you drill and tap them under neath and use a grease gun to push them out.
http://rollingperformance.com/rotorbearingreplacement.htm
Tools
Drill and tap the red holes (pic is after greased them and removed)
Thread your NPT pipe in and hook to grease gun
Pump until the bearing pops out.
If I'm not mistaken, the gen V bearings are open on the back side. In that case you could just fill them with grease and hammer a close fit pin into the bearing. That should force the grease behind the bearing race and pop it right out. I use this trick on carrier bushings in flywheels.
