how to replace PS pressure line
nastypvp
I have a 2001 gtp with a pressure line from the power steering leaking I put it on a lift and seen that its gonna be hell my ? Is am I gonna need to drop the cradle down from the body to get the the nut in the back side of the motor and should I replace the return lane while I'm there also
if you lower the rear of the sub frame a few inches you'll have the room, its a 18 mm line nut.
if its leaking from the nut theres a o ring on line, it maybe bad. some times you can snug it up a bit and it will stop leaking. mt new rack came with new o rings and i never used em. old ones looked good. no leaks.
Return line should last forever, never replaced one before. Unless you damage it messing with other stuff.
