How to replace lights in door & steering wheel switches in 2004-2008 GP's?
Flocarino
I try to find a write up with pics on how to replace burnt light bulbs on the door and steering wheel switches for a 2004-2008 Grand Prix?
can anyone help me out?
thanks
the radio controls pull out of the wheel, then you need to take them a part carefully or they will break. check the lighting area, interior section.
or the how to section. use google if need be to find it, add grandprixforums in quotes to guide you back here.
search box here is dead center of the screen in a blacked out box.
I know that they pull on a 97-03 GP as I've done it several times but I just don't see how to pull on them on a 2005 GP.
I know this is an ancient thread, but did anyone ever posted a "how to" for removing the the audio control buttons from the steering wheel on the 04+ models. I have seen the write up for the early cars, namely 1999 (I think) but can't find instructions for the later models. Any helps/thoughts/links would be appreciated.
The service manual is available for download here. Can probably find it and see if there's more to it.
Here's for replacing the cruise control switch. The buttons should come off with the wheel cover/shroud.
