How to removing mps hub
fbm
Has anybody found a way to remove the mps hub without buying the adapter or making a adapter
I used a hydraulic press... but I also took the snout completely apart. I don't think theres another way to do it besides those two options
yeah the only tool you can use, its called a supercharger pulley puller, its not at your local parts store either. we got a guy here who sells then and rents them. same guy who makes IC's in the for sale section, its a sticky, so its always up top
No I have a intense puller it's the mps hub on my gen 3 that I need to swap on to my gen 5 I thought I heard of someone using a 7/8 or 1" wrench behind the hub to pull it off I can make a plate like intense or zzp but if zzp uses a aluminum plate to pull it off why would a 3.4 pulley not work or even mount the pulley on backwards so the pulley would no crack . I like the intense way because there is no chance to pull a thread or break a bolt
newbs..
You need the right SC pulley puller to start off. Instead of buying ZZP's tool etc. Just take two of your largest wrenches 18mm/19mm and put them behind the mps to make it bigger. Use puller like normal.
