how to remove the rear driver side door panel
curllytop
My rear driver side window is off track and i need to know how to remove the door panel so i can fix it. Any links or direct instructions would be helpful thank you
Two bolts (T-25 if I recall correctly but a 5/16" allen wrench will also work) near the door handle are all that holds it in place. Well, that, and a bunch of those little plastic pull tabs. Just yank. You won't hurt them.
