How to remove my dash?
nikkigpgt00
Is there a complete write up on removing the dash and the gauge cluster? I bought some gauges and need to see how hard its going to be to do the job? From what I remember removing the dash isnt too bad but what is involved in actually removing the gauge cluster to get my gauges on? Would it better to do it without removing the cluster?
2 screws in the knee pad under the wheel. Then you just pull the dash bezel off. Then you can get at the cluster, it is like 4 bolts to remove.
Ok, pop the dash off (you'll need to put the wheel as low as it can go)
Then there are 2 screws at the top of the cluster that hold it to the back of the dash support.
Unplug both connectors.
Unscrew the 5-6 screws holding the shield on the gauge cluster.
DONT **** WITH THE NEEDLES.
uhhhhh i "****ed" with the needles when i cut that stupid overlay out, u just cant take em off, u can move em around, it wont matter. if they dont go to where they should when u turn it back on they were ****ed anyway. still be carefull and dont touch em if u dont have to.
