How to remove glove box?
04GTP956
I need to replace the air inlet actuator on my 2004 grand prix, however I'm having problems getting to it. Does anyone know how to replace this part or how to remove the glove box?
Assuming from your profile picture you have an 04+, remove fuse panel
Pull off the floor board cover under dash there should be too plastic pins you can use a flat head screw driver to pry them out
Then pull the plastic dash peice off
open glove box there's this black plastic part grab like so and push it to the left
Now unscrew the 4 screws on the glove box then done, it's really easy honestly
Thanks, I've been able to complete these steps but when I try pulling the glove box out it seems to be attached from the left hand side. Should I just pull harder? I don't want to break anything.
Wiggle it a bit It should come right out there's only 4 screws holding it in, becarefull of the wire that goes to the glovebox light
