Bronco Boy
Donating Users
Copying how I did my previous Piaa/HID/Fog set-up, I started with some Morimoto XB LED for lights from The Retrofit Source, some stock fog lights, and some old 9007 and 880 bulbs; I kept the HID wiring harness in play, so needed and adapter harness to go from 9007 to 880.
The XB LED kit:
Stock lights from the junkyard:
Remove the lenses from the stock lights:
Remove all this crap from the XB LED’s:
Apply adhesive to the inside edge of the stock housing, and to the outside edge of the LED light and join the two together:
After the adhesive has cured, remove the glass from the 880 bulb and solder it to the LED light wires:
Lights are done:
Bench test:
Remove the glass from the 9006 bulbs, solder wire to them, then solder the other end of the wires to the 880 plug:
Attach the stock bracket to the lights (they aren't pretty, but you won't see this part of them in a few minutes):
All done!
The XB LED kit:
Lights are done:
Bench test:
All done!
