how to do the perfect intake job?
krsdadsps
Okay guys doing my lim and upper again. what are the tips to do it wright? and what is the torque on the lower intake with the felpro metal gaskets? and how to bleed the system perfect?
iirc i went 15 on the lim bolts, no idea what n/a intake spec is.
if you fill the rad then fill the block from there the t stat is, then put the t stat back in bleeding will be minimal.
i like to let it idle rad cap off till the fans come on, then open the bleeder on the t stat housing. leave open till coolant comes out in a steady stream. top off the rad and cap it.
recheck the rad level the next morning when its ice cold, top off if needed.
also best way to get the surfaces clean? I don't want to do this again, car is driving me crazy. also what it the part called that the belt tensner and heater hoses run into mine has a crack
alternator bracket. it comes with the tensioner. junk yard would be the cheap way, they run like 75 and more new.
new razor blades to scrap the crud off, brake cleaner and a rag to wipe the surfaces down with. thats all you need.
alright, checked my junk yard and will be $15 much cheaper then I thought. once I seen the crack I was like ooooh **** thanks Pontiac for eating my wallet again lol
Well guys got it together and it is running great. i got some sea foam spray and cleaned the lifters and push rods. and cleaned the throttle body good. also insted of useing the black sealer i used the copper is it any good? And also i replaced the part that sits in between cyl 1 & 3 that has the vacuum line running to the throttle body. And i belive the one hose says evap? but mine was clicking like crazy. and it is running better then the day i bought it. also the little screen in the throttle body i read it helps some with intake to keep it out. is it okay to do that?
I use copper exclusively, it's perfect to use.
The throttle body screen should be left in place. In our situtation it keeps the maf reading properly.
Also flipped the wish bone mounts and i didn't think it would do much but wow did it. everybody needs to do it lol. just orderd the motor and transmission mount and got some wagner thurmoquiet pads slotted rotors and new brake lines. now i can get some wheels. Do the suspension. the sound system and do the inside and out and a top swap but gonna wait on that since i just done the top end on this car but it is finely coming together
if your buying all new rotors and stuff, its the best time to up grade to a set of F body brakes up front. by far the best mod for first one. stops so much better.
I may just send them back and do that if its much better. I'm all about being able to stop, don't want to put all this $ into it and end up totaling it because i cant stop. but anything what do i need off a f body to do the swap and how hard is it? or do you got a link tried the form search and came up with nothing. good thing is at the local pulla part there is a 99 camaro v6 i can grab the parts off of
its like night and day. buy good pads. those wagner pads sucked BTW. very cheap and wore fast, and dust every where with the F bodys.
im using posi stops right now all around, the rears were like 20 bucks off ebay, the front f body pads were like 60. R1 concepts sells the same pads for 100 and 40 iirc. i just googled the part #'s they had listed.
I may go with hawk or ebc pads but i read it and i have one question can i use the factory wbody brake lines or fbody?
so today i took a trip to roanoke, va (327 miles) i had no cel light on and once i got to roanoke and pulled up to a light it came on. went straight to advance and got it scanned and it came up with a po121, po122, po118, po135, po141 and po155, unhooked the battery for awhile, made the 327 mile trip back and never came back on, what would have caused this? also the car has a new acdelco and a 180 thermostat in it. i think im going to throw back in the 195 thermostat and pick up a tps sensor and temp sensor from the junk yard and replace them. do you all think this will clear most of it up?
look for a damaged wires to the tps and the temp sensor. that whole area bakes with heat, wires fall a part.
also check the fuse box for a blown fuse, if the fuses are all good the o2 maybe bad, or its wires are bad.
Another random question, my car did have the catfish front bumper and i put a gt bumper on it. There was a huge plastic shilded covering the whole radiator. i removed it what was the point in covering the radiator like that?
