Thanks for the suggestions. Yeah I have been in tight spots on changing plugs, on my 2.3 Ranger it has 8 plugs and and they were a ***** to get to, but I was able to with some sockets and joints
Well I got them changed out the other day. Mileage went up a few mpg and im happy with the results. acceleration is also better.
Just ask Geddy what happened to my hand when I changed his plugs.Wow, you really needed new plugs didn't you.:th_thumbsup-wink:
Reptile, I thought anti-seize was only needed with aluminum heads. I never use that stuff on my plugs. Of course my plugs come out quite often.![]()
I used the NGK TR55 Split V Copper. There were copper plugs coming out so I didnt think it would hurt to put them back. Guy at the counter told me iridium is OEM. The plugs that came out were Delco Copper and with only 69 thousand miles when I got the car I doubt they had been changed.
There's nothing wrong with the plugs you put in if they run fine in the engine. GM simply started using platinum plugs purely for the longevity.
