Just finished changing my camber rods (originals were bent). Not the hardest job, but thought I would give some info anyway.
1) Raise car and support on jackstands
2)Remove rear wheels
3)Use 2 13/16 wrenches to remove center nuts. (bolts WILL NOT clear the trunk YET)
4)Remove the nut holding the outer end of the camber rod (13/16)
5)Loosen (do not remove) the 2 bolts on either side of the crossmember (4 in total)
6)Pry back the crossmember in order to gain clearance to remove the centre bolts.
Installation reverse of removal.
Dont think I missed anything. Also a good time to replace rear sway links.
