After a lengthy period of a business refusing to honor a price match and two phone calls to customer service, I do believe the tire shop I've been with finally got me back.
Monday I went in for an alignment and found out my trailing arm was damaged, so I replaced it. This morning I took it back and upon the car being returned to me the service writer claimed that my tie rod jamb nuts were seized and they had to heat them up, and as a result they were likely "welded in place" (his exact words) and the vehicle likely wouldn't be able to be aligned again.
I have spoken with the store manager which became heated after I let the BS word slip in reference to applying that much heat to my tie rods, and I'm taking it back in the morning. However I am concerned even if they get the nuts loose again (most likely a short term fix as they will re-"weld" themselves to the inner tie rod upon cooling) that the structural integrity of my inner tie rods is ruined.
Seeing as how they're only 13mm thick at the thickest point, would any of you be comfortable with anything other than a replacement of both inner and outer tie rods?
