How hard to fix???
duane9586
I have a 2005 GP that was a base model. Now i have since did a swap to the l32 and ever since i put the engine in and the pcm in (overkill) i have had the code P2761. I don't notice any problems with the tranny itself except that the traction control light on the dash is always on and it doesn't work and the check engine light is on. I know the sensor is inside the tranny....how hard is it to change? I need to get this fixed so i can get my check engine light off for inspection. TIA
What is the code for? Sorry i'm lazy and don't feel like opening up my tuner. lol
I don't think it's an easy fix but I could be wrong. And I don't think it has anything to do with the pcm or engine that you put in. I have personally never heard of that happening.
Have you had the code or light on since the swap? Scotty I cant even find that code anywhere! None of the repair info that I show has any codes in the P2000s
i found the code on alldata and if i take the light out when they hook up the computer it will still show a code. i think i may just have the code removed
