How do I take this off?
K Kraziee
How do I remove this egr tube from the exhaust manifold? I bought the backing plates from zzp and the intake one had a 13mm bolt that just comes right off, but the exhaust side looks like it is like welded into the plate. I tried a 13mm socket and it just turns cuz its like welded on or something. Guys got any advice?
Sent from my PantechP8010 using Tapatalk
I can't for the life of me get this off. I'll pay someone $50 to come do it for me lol
its a nut and bolt, so on the back side is a bolt head, and then theres the nut you can see. so you need 2 wrenches. or a wrench and a socket.
But the bolt on the back is like stripped and the front where the tube starts on the bottom where I took the pic, no wrenches or sockets fit on there. It's like a circle
The bolt ..is out of sight. It is at an odd angle and requires a bit of trying. If it's stripped, then you are effed. The side you can see is a flange like Bio said and there's no turning it.
Only other way to get that out, besides turning the bolt the proper direction, is grind it off.
I was able to get it off with a 10mm socket. It was such an awkward angle so I had to lower the wrench in slow so I did't drop my extension. Came off with some force. I hope black silicone rtv is ok cause that's what I used. I should've picked up high temp stuff, but I already had a bottle of the black stuff. BTW thanks for the advice guy's.
NP, we like to help out.
Reason for me mentioning it's either a 13 or 10 was so you'd have the right tool. Either the socket will be too small, too big or just perfect.
Ya, I was futsing around with a 13mm and it seemed like it was the size, probably caught it on an angle that's why I thought it was stripped. Put the ten on and it took some force, but finally budged.
