suitercrew
Like title says how can I measure at what level or percentage my injectors are before they max out? I have dhp and torque pro.
Sent from my LG-H901 using Tapatalk
But what's the max ipw?with dhp you scan injector pulse width, "ipw"
I havent seen anything that said injector duty cycle in dhp or torqueWatch injector duty cycle.
Anything over like 90% is pretty much maxing them out.
Ok so IDC=PW/(120/RPM) is the parameter I should add?Pulse width by itself tells almost nothing, because it depends on rpm. Having a 20ms PW at 4500rpm is completely different than 20ms at 6500rpm.
If you have dhp, I think you can create a parameter to measure idc.
IDC=PW/(120/RPM)
Ya I have 42# but I'm also running e85 on a 3.4 setup and stock pump. But supposedly Arizona only has e54 which would obviously give me a little more head room with fueling which is why I have no idea where my injector duty cycle is at currently. I would assume it's getting up there and I'm in need of bigger injectors if I want to mod furtheri was hitting 24,000 wot top of the rpms on a 3.2 pulley, installed 42's, now hits 16,000.
3.2 is about the smallest you can go on stock injectors, but you would be right on the edge of maxed out.
If i added this parameter how would I know what the "max" would be for my setup?
Thanks man I will check that out when I get off work. I finally fixed my stupid dhp last night so I took a scan and after dropping to a 3.4 I'm seeing around 18.5 ipw at wotJust go to google, and type in "Injector duty cycle calculator". The first link should be for Stealth 316, you just punch in your info (RPM and IPW) and hit calculate, boom, IDC.
