How about a little wiring help?
traildog
Banned
I'm trying to wire the lighting on the gauges and get the AeroForce to power up and down properly.
I have the "add a circuit" fuse holder to plug into the fuse box, but, I need help figuring out which slot to plug it into.
What say you gauge wizards?
Use the radio fuse or a IGN fuse.
Make sure if there is a red jump on the back of the aeroforce, it needs to be removed to work with a 12v power source.
You really shouldnt use the same one, it could overload the circut.
I use both the radio fuse and a IGN fuse for my gauges. That way both are on with key on engine off and shut off when I eiter turn the car off or open the door.
Ok. I'll buy another "add a circuit" and separate them. Can't wait till they function properly.
Thanks for the help.
3 gauges will not OL a 10amp fuse... Just sayin!
One (add-a-circuit) is fine, just make sure you chose a good ground point. The ground bar just by the brake pedal, is a good spot.
