Hopefully not supercharger!! engine noise w/ vid
If coolant elbows aren't cracked/leaking check water pump... take off belt and wiggle it if it has play its probably bad. Try the stethoscope method for knock... buy one or use a long screwdriver metal end on spot to test put your ear to handle. Just watch where you put it.
