Hi all,
A few days ago I felt some misfires at idle, so I plugged in my scan tool and am indeed showing some misfires on Cyl 2 and 6, but only when completely unloaded (at idle and in park/neutral). No DTC's, and everything looks normal on the scan - except that LTFTs are between 11 and 16.4% (which is the max for positive correction, if I'm not mistaken?). The value occasonally drops, and the more the load on the engine, the lower the LTFTs. They're 0 at WOT. The STFTs are usually near zero, so it looks like it's not catastrophically bad, just weird.
Obviously this suggests vacuum leak.
But I redid all the vacuum lines some time ago with nice silicone lines. I started checking hoses by unplugging them (and manually plugging the ports), and also by spraying around the S/C and all vacuum ports and hoses with carb cleaner (carefully) to check for changes in engine revs.
Everything seems fine. I can't find any leaks anywhere.
Also - the scan tool shows vacuum at 20.2 inHg. That's quite high, IIRC, and it's also normal for my car at idle and matches exactly what it normally shows, from before this problem developed.
So then I suspected MAF or other input air sensor failure. I swapped the MAF with a friend's known working one - no effect. Also the MAF shown at idle (~4.7) is correct, as is the IAT.
It's not the upstream O2 sensor. That was due for a replacement anyway and I put in a new (OEM) one, to no effect.
So I'm sort of at a loss here. I tried searching for other threads with similar issues but couldn't find anything that wasn't either a vac leak or the MAF.
Has anyone seen something like this before, or has any suggestions for what to try next?
Thank you in advance!
