Hids in fogs
99gp
Hey guys, a few weeks back, I put some of my buddies hids in my foglights. They did good for about a day, then I went to show em to my dad, flipped the switch and they both just went on and cut out at the Same Time. I checked all the fuses, it didn't blow a fuse, did I f up the wiring? If I throw my stock bulbs back in should It work? Any help appreciated, thanks
Actually Let me correct that. I went through each fuse in the fusebox in the glove box, didn't see aburnt one, al though I wasn't sure which fuse is for the fogs
Fuse is under the hood for the Fogs IIRC.
Yeah it is in the fuse box under the hood. You can sneak away with putting a stronger fuse in there, but the best thing to do is put in a HID wiring harness/relay.
