gptrell502
ok so now i want Hid's and dont want to spend a arm and a leg. i want 8000k for that blue look. Anyone recommend a good cheaper kit cuz zzp is only 600k also were do i get the extra harness thing so i dont mess up anything thnx
the guz- do you have any pics of your 5000k?
Yes that is the harness. Get the single if you are doing a low beam only set up and a bi-xenon harness if your going to do low beam and high beam set up that uses 4 ballasts.is this the harness i need?
do you think i would need the harness for for lights or should i just get the plug and play ones?
