Hello! I am the driver of a burgundy Grand Prix GXP. I love my car, and am glad there are so many GP owners on the internet gathered on forums.
I am planning on doing an HID\projector retrofit into my existing stock headlights using the Morimoto mini H1 kit from TheRetrofitSource.com. This is my planned method for my retrofit:
1. Remove current headlights
2. Heat to 150 degrees, 8 minutes
3. Pry assembly apart
4. Remove old bulb assembly
5. Cut 2.75 inch hole, CENTERED, with hole saw.
6. Mask off assembly.
7. Spray paint chrome reflector black
8. Spray paint shrouds cobalt blue
9. Dry
10. Install projectors into hole
11. Install shroud
12. Install HID kit
13. Install angel eye
14. Aim, adjust.
15. Seal with epoxy\silicone on back
16. Wet sand and buff front and back of lenses
17. Reattach front with glue.
18. Reinstall tightly to car
19.. Aim with in-built adjustors.
Now, I am pretty incompetent with anything electrical and\or automotive, so I'm assuming there are problems in my plan, or things I am unaware of. I would appreciate any advice anyone could give me on the proper method of doing retrofits, and anything I may be doing wrong. I will also be sure to check this forum for other retrofit threads for ideas. Thanks.
9. Dry
11. Install shroud
12. Install HID kit
14. Aim, adjust.
