HID problems :(
Hamnjelly
Alright so I have a 1998 grand prix gtp, and I ordered HID's from HidHeadlightKit.com, the bi-xeon ones for high and low beams. First off, when I have low beams on the light is lighter than when I turn on high beams. Thats not so bad, but I also noticed that my dual climate control lights pulse when ever the hid's are on. If I dim down the lights on the inside then it will stop pulsing. Any ideas????
you must have hooked something up backwards. check all youre connections and double check the install directions. also you may want to have the alternator tested as the bristles may be worn down and not generating electricity at the same rate as in its newer days. hope this helps.
