Hid lights
i desperately want to buy 6000k HID lights for my 07 gt but im not sure where to find them or what the sizes are. I know that i want both high/low and the fog lights as well. Can anybody please help me out????
9006- low
9005-high
zzperformance.com
wbodystore.com
ebay
and don't forget the separate wire harness for the hid kit.
yeah, i'll go in on a group buy, i also heard that i would have to change the wires that run to my lights because the HIDs would burn them out, is this true???? and if it is, does that kit u purchased come with the wiring as well???? thanks for all the help guys
Yeah you'd have to, I'm probably going to buy some pure white HID's for mine sooner or later, just a few other projects ahead of it.
4300k is definitely not pure white. They're not extremely blue, but there is a fairly good tint to them.
Sad fact of the matter is most people just get their HID's because of teh purdy color. Instead of trying to optimize their light output.
6000K is a good range for decent light output. either way the headlight capsules suck for any sort of light output.
I had 4300K, 5000K and 6000K. The 4300K I had were white. The 6000K's had more blue than the 5000K. I ended up with 5000K in my projectors. They appear closer to OEM and provide good light output between the two. I also run a relay harness with mine for the headlights and fogs. The harness prevents flickering of the lights and protects your factory wiring. I am not sure if an 07 uses the headlights for the DRL's. Its a good thing to disable them but I know its not that easy for an 04+. Someone on gpona.com posted a thread on using a wire from the corners as the trigger for the harness and bypassing the DRLs. If I find it I will post it.
