HID Lights
jonnyo81
Alright,
I have a 2001 4dr gtp, i have installed HID lights from a company called HID Canada. Everything has installed good, but when i turn on my fog lights the hi beam symbol comes on in the dash and HUD, but the funny thing is it will flicker on and off, but if i turn the fog lights off the hi-beam symbol works properly. Any ideas???
OH and i have both headlight and fog light HID's. and they are 6000k.
i dont understand what do you mean a harness?? everything has plugged in properly?????? Am i missing something???
Are relay harnesses safe? I put mine on and after it was set up the male headlight plug on the opposite side of the battery had nowhere to plug into and the two females on each bulb had no where to be plugged into, is it safe or normal to leave them hanging there?
Switch the pins in your relay harness where it connects to the stock oem pigtail that's on the back of the headlight, blue connector. Ground was in the middle of mine, then blue and white pins on outsides. Just swap them til it's fixed.
how did you go about installing the fog light hids i cant understand what the 2 wires that have no connectors on them?????? where do they go?
answered in your thread.. pull out the stock light put the connectors in there.
