hid lighting problem
rockquarryman
hey yall, just got my hid kit in yesterday, i installed it. waited for the night time to adjust them and i noticed that after wiring them that they are wired as my low beams only come on when i hit the high beam switch, and vice versa on the high beams. I have tried swapping the bulbs from side to side and turning the plug around as well, but to no avail..:confused::confused::confused::confused:. I asked a friend of mine and he told me to swap the wires on the oem plug and they should work but that didnt help either. when i changed the wire one light went to low beam but the other stayed on the high side and i noticed my high beam indicator light was on ever so dimly im so lost i dont know what to do any more Please Help thanks.....
No idea what kit you bought.
The high beam light will be on but dim with HID's, it will even flicker on the heads up display sometimes. It did for me anyway when I ran my custom projectors.
I asked a friend of mine and he told me to swap the wires on the oem plug.....
Your friend is correct.
If you failed at this, please post more info on your harness and how it is wired up. I don't buy the fact that one bulb now works fine while the other is not; they get the same signal via the harness.
