HID issues
99prixgt
club of used to own a gp
I recently installed the 9007 HID kit from zzp. I am having a few issues with them. I can't figure out why, but sometimes the passenger side HID dosent turn on, but then i flick on the high beams and it works no problem. Sometimes i have to turn the lights a couple of times to get them to both work correctly. The kit mentioned something about using a 20a fuse but there is a 60a fuse in its place, in the fuse box under the hood. I tired looking for a 20a thats that big but i couldnt find one. Any ideas?
Ballast not getting enough voltage to ignite the bulb.
They need a rewire a relay harness to pull power straight from the battery and not go through the whole cars wiring
I used a voltage booster to help with that issue. works great..... but every now and then it happens. but it is significantly reduced....
Voltage booster only works when car is running to get to restre of system and still by the time it gets to main light if using stock harness still not enough voltage most times.
Need a relay harness to pull power directly from battery
