Hid help
Mrc728
SO Ive searched and searched about HIDs and cant find anything on the installation of these. I got the kit from vvme with the relay, I know where all the connections go except the two wires coming off the relay itself. Not the ground and positive, there are 2 smaller wires coming off of the blue connector. where do these go?
Thank You
Take the harness off and plug it straight to your stock harness. You don't need a relay harness.
But, that wire in your picture goes to nothing. Just leave it be.
the blue connector attached to the bulb does jack ****
the one that is in the back right is for the relay harness. also the moment i get a pair of bulbs i cut that rubber circle out and remove the extra connector so there is not any confusion
and i highly suggest a relay harness on any vehicle w/ a "conversion" kit like this one
especially if you are leaving the drl enabled
^^^ that one the two is for bi-xenon bulbs
Yeah I hood it up without the harness, everything works great, no idea what u mean by my copyright crap.
