Hid help needed
I just got my HIDs back from WBS for a warranty replacement. And they are doing the same exact thign my old set did, leading me to believe its something with my
car
Keep in mind it does this WITH and WITHOUT the relay harness installed..
When i first turn them on the pass side will flash and go out, but the drivers side works perfect. Then when i shut them off and turn back on they both work perfect. Let the car sit for a bit and the pass side will not work again, drivers side still works. I know for a fact its not the ground as I am using a body ground and get almost no resistance according to my multimeter. I have already tried switching the ballast and bulbs as well and the problems stays on the pass side....
Leading me to think its a problem with the cars wiring somewhere...
Anybody ever experienced this or have any idea whats up?
Eric
nevermind, I figured out the battery was too low to run both HID's, started the car and they both work
I was fighting with my hid's for a while with the same problem. Even though I was using a relay harness wires were too thin. I ran new wires on the high amp sides of the relay and now they work great if the car is running or not.
